. They are looking for a Building Services Manager to coordinate mechanical and electrical services from design through to completion. About the Role...Building Services Manager Location: Various Locations Type: Full-time, Permanent Industry: MEP About the Client...
: As the Building Services Manager, you will oversee the management and coordination of complex MEP (Mechanical, Electrical...About The Role Job Title:Building Services Manager DIVISION:Build LOCATION:Bath CONTRACT TYPE:Permanent BENEFITS...
all systems operate as design, design and validation teams are satisfied and building users trained in operation. Provision...Building a sustainable tomorrow BAM UK & Ireland is currently recruiting for a Building Services Manager to join the...
Building & Construction Project Leader to lead capital investment projects from initial feasibility through to design, delivery... and manage project risks and opportunities. Prepare detailed design briefs for building services, refurbishment and major plant...
planning, management, and coordination of Building Services design with other disciplines, across all project stages..., compliant and technically robust design solutions aligned with programme, budget and quality expectations. Design Management...
infrastructure environments. Experience in managing commercial processes, systems, and tools (including cost management systems... management of Building Services and multi-d projects and frameworks at Heathrow, providing strategic direction across the project...
Acumen Good understanding tendering/estimating and cost management for BMS hardware design, software, and graphics. Working... transformation Experience in Project portfolio management (PMO type of role), Project Manager and/or Engineering Manager of BMS...
Design Engineer looking to work on complex industrial systems within a global engineering environment? Join a global leader... in fluid-flow technology, supporting the design, development and improvement of control systems for modular and packaged...
and technical advice in a WSP project manager capacity on a wide range of projects. Reviewing design programmes and ensuring... with a proven track record in delivering design engineering projects for your discipline and in line with client expectations. Work...
) including wiring schematics, SLD's Transformers at 20kV/10kV to 400V. · BMS (Building Management Systems) and SCADA... with and management of internal and external stakeholders Carrying out design and calculation work using relevant industry software (eg...
